It is currently Sat Aug 02, 2025 7:52 pm
PostPosted: Sat Feb 02, 2019 12:21 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I thought I would share some photos of my rebuilt motorized dish sander. I’m tickled pink with the improvements I made. I’m looking forward to putting together some improved dished workboards to go with this gizmo.
So, the motorized dish originally worked OK, but there was slop in the drive mechanism for the dish itself. The improvements (stolen 100% from others here on the OLF) fix that.
Here are photos of the front and the top, to give you an idea of how it works:
The motor is a 1750 rpm motor I harvested from a cheap Harbor Freight belt/disk sander. I have mentioned before how this is a cheap way to get an electric motor. I also reused the pulley from that HF sander.
The pulley attached to the motor is 1 5/8”. It drives a 4” pulley on shaft #1. That reduces the rotation to around 711 rpm on that shaft. Also on shaft #1 is a 1 ¾” pulley. It drives a 10” pulley on shaft #2. That reduces the rotation to around 124 rpm. I actually clocked it at 119 rpm. The shafts are both 5/8”, because that’s the size that fit the pulleys and drive plate I wanted to use. The shafts are secured by flanges with bearings of the right size. Here are photos of the inside:
Shaft #2 drives what I call the drive plate. It is the aluminum disc from a 12” disc sander. I bought just the disc as a used spare part on eBay. Here are photos:
I have shaft #2 sticking up about a half inch to engage a slightly enlarged 5/8” hole in the center of the dished workboard. This ensures that the dish only rotates, and doesn’t wobble around, which my prior inferior drive mechanism allowed. The other pin sticking up is a router table starter pin that I bought from Rockler. It is smooth on top and has a ¼”-20 threaded mounting nub on the bottom. I drilled a hole in the drive plate about 1 inch in from the edge and secured the starter pin to the drive plate with a regular nut. This is the rotational drive pin. It engages another hole in the bottom of the dished workboard, 5" off center.
The casters are just regular casters of a height and in a position that allows them to be sort of a failsafe to avoid tipping of the workboard under heavy load. The drive plate is 12” wide, so tipping probably won’t happen, but the casters make sure. Shaft #2 is strategically extended just the right amount to have the workboard bottom either slightly graze the casters or ride on them lightly. This is all meant to help avoid deflection of the workboard. I like thick workboards, so deflection is not a huge issue, but it is good to guard against problems.
There are covers for the front and back of the box, so that fingers and other body parts don’t get tangled in the belts during use.
This might sound like a lot of work, but compared to driving the bus a few times, I am happy to have this.
Improved dust collection for this comes next.
These users thanked the author doncaparker for the post (total 4): Ernie Kleinman (Sun Feb 03, 2019 11:07 am) • Pmaj7 (Sun Feb 03, 2019 4:17 am) • Terence Kennedy (Sat Feb 02, 2019 2:39 pm) • Michaeldc (Sat Feb 02, 2019 12:47 pm)
PostPosted: Sat Feb 02, 2019 1:30 pm
I would like one of those one day...
PostPosted: Sat Feb 02, 2019 2:52 pm
Last Name: Parker
City: Charleston
It's really not hard or expensive. I couldn't tell you how much in hard costs I have in it, but it can't be more than a few hundred bucks. It just takes a little time to tinker and put it together.
PostPosted: Sat Feb 02, 2019 3:33 pm
You know I used to think I really wanted one, but now I'm getting better at marking the sides on a radius dish and cutting to the lines (spoke shave/block plane) and it's only a minute or two on the abrasive in the dish to and a few minutes more for the back.
Besides, can't swing a cat in the shop with stuff now gaah
PostPosted: Sat Feb 02, 2019 4:08 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
I'm in the same boat so I mounted mine on the wall [:Y:]
I really need to get a better profile pattern for my sides though or something. What's your method?
PostPosted: Sat Feb 02, 2019 4:11 pm
I wish, no wall space either.
PostPosted: Sat Feb 02, 2019 4:21 pm
Joey, there's a tut around here somewhere for that but I'll try to explain it, or at least what I do...
I take cardstock from the dollar and a half store and make a piece 5.5"x 32".
Then I line the inside of the mold of whatever body template I'm making, with one edge of the cardstock aligned with the edge of the mold.
Then place the mold in the radius dish, find a big fender washer, and roll it around the mold with a pencil in the low aspect of the center hole tracing a line on the cardstock. Mark waist and end points and voila. Gets a very accurate profile which pretty much matches the dish exactly after bending, save lot of time.
Sorry for the derail...
These users thanked the author meddlingfool for the post (total 2): Pmaj7 (Sun Feb 03, 2019 4:23 am) • fingerstyle1978 (Sat Feb 02, 2019 5:06 pm)
PostPosted: Sat Feb 02, 2019 5:07 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Thanks, I've been going about it all wrong lol. Seems pretty simple now that I think about it. I guess I'm a dumb#$%!!!
PostPosted: Sat Feb 02, 2019 5:42 pm
Often the obvious is only so after someone else points it out. I didn't figure it out myself, that's for sure...
These users thanked the author meddlingfool for the post: Bri (Wed Aug 21, 2019 9:29 am)
PostPosted: Sat Feb 02, 2019 7:25 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I do a variation on the method Ed uses. I run blue painters tape along the inside of one half of the body mold sitting in the radius dish and then scribe the profile on the tape with a pencil in a small wood block (I'm going to steal Ed's idea of using a fender washer for the next time. Should have thought of that). I then transfer the tape to a 32" long piece of poster board that's pre-marked for the body depths at the neck and tail ends. I then cut the profile along the scribed line on the tape. The side profiles I've gotten this way are very close to the final profile and take very little time in the sanding dish.
These users thanked the author J De Rocher for the post (total 2): Pmaj7 (Sun Feb 03, 2019 4:26 am) • fingerstyle1978 (Sat Feb 02, 2019 7:37 pm)
PostPosted: Sat Feb 02, 2019 7:38 pm
First name: Joey
Last Name: Holliday
City: Palmetto
How did Torres eve figure all this s&*$ out with no power and no internet? Lol
These users thanked the author fingerstyle1978 for the post: Pmaj7 (Sun Feb 03, 2019 4:26 am)
PostPosted: Sat Feb 02, 2019 7:39 pm
No ideas in that were mine, they're from someone else's tut...
PostPosted: Sat Feb 02, 2019 7:54 pm
First name: Jay
City: Bothell
State: Washington
Don - That's a cool design. With it sitting on the bench, what's the height from the benchtop to the upper surface of the radius dish?
PostPosted: Sat Feb 02, 2019 8:19 pm
Last Name: Parker
City: Charleston
Thanks, Jay! I don't use it on the bench, because it is not super portable (kinda heavy and a bit bulky), and it would sit too high for me during use. I only had it out on my bench for working on it.
The dish sander normally lives on top of a homemade plywood storage cabinet that's about 19" tall. The dish sander box is 14" tall, and the top of the drive plate sticks up about 2 3/4". If you figure a dished workboard of about 1 1/4" thick, that would put the top of the dished workboard about 18" from the bottom of the dish sander's box. With my setup, that puts the top of the dish at 37" off the floor.
If a person wanted the working surface to be at about benchtop level, she/he would have to do something similar to what I have done: Put it on a lower platform. The motor and the shafts need about a foot of vertical space inside the box.
These users thanked the author doncaparker for the post (total 2): Ernie Kleinman (Sun Feb 03, 2019 10:16 am) • J De Rocher (Sat Feb 02, 2019 8:56 pm)
PostPosted: Tue Aug 20, 2019 11:36 pm
This is great. Thanks for sharing, Don.
PostPosted: Wed Aug 21, 2019 5:40 am
Last Name: Parker
City: Charleston
My pleasure, James.
As an update, I mentioned improved dust collection as my next goal for this homemade machine. I later built a set of easily removable walls (about a half foot tall) that create an octagonal box around the top of the sander, with one of the eight walls being a rectangular HVAC vent that feeds into my dust collector. Even with a ClearVue, it doesn’t capture all the nuisance dust until I brush it toward the intake, but I’m hoping that it does a good job of capturing the tiny stuff before it gets too far. I wear a fine dust respirator during sanding, just to be sure. This arrangement doesn’t interfere with normal operation of the sander, and it keeps the nuisance dust inside the box for later cleanup, so I’m happy with it. It’s hard to imagine a dust collection method that would catch everything with a machine like this.
Added bonus, however: I later realized that, with this octagonal box, I was 90% toward building a downdraft table. I just cut a piece of plywood to fit the top of the octagon, drilled a bunch of 3/4” holes in the plywood, and set it on top of the octagon. It seems to work OK! A dedicated downdraft table would be more efficient, and I still use a respirator, but it was worth the very small amount of extra effort, given what I had already built.
I could post a few pics if anyone is interested.
These users thanked the author doncaparker for the post: James Orr (Wed Aug 21, 2019 10:47 pm)
PostPosted: Wed Aug 21, 2019 6:27 am
For those with limited space, appropriating something from the kitchen might work. It has three speeds and is compact and portable. You can still use it to mash potatoes (even while sanding if you don't mind high fiber). I've made two motorized dishes - the other used a bowling ball balancer. Both were cobbled together in just a few minutes by mounting a dish on an existing mechanism.
These users thanked the author Clay S. for the post: Michaeldc (Wed Aug 21, 2019 7:07 am)
PostPosted: Wed Aug 21, 2019 10:47 pm
I’m wearing one if I’m doing ANYTHING that makes dust (as opposed to shavings). I don’t have the allergic reaction some do, I just hate feeling gunked up. And I use my netti pot after.
PostPosted: Thu Aug 22, 2019 6:53 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Don quick question, what is the sizing on those wheels ? are they also hf ?? thanks
PostPosted: Thu Aug 22, 2019 7:10 am
Last Name: Parker
City: Charleston
Ernie—
I think I bought the casters on eBay. They are 2 3/4” tall, which probably means they are 2” diameter wheels. I am pretty sure you can buy similar casters at Harbor Freight. They have lots of sizes when I go in there. I think I remember considering smaller casters, but they felt too small and flimsy for the task.
You have to consider how high up off the platform you want the drive plate to sit. Recall that I needed to give shaft #2 (photos above) a booster seat inside the box in order to get that shaft to stick up a few inches from the platform.
I think buying all the hardware is the first step, and then you can cut the wood to work with the hardware. And, of course, all your shafts, pulleys, bearings and belts have to be coordinated.
Users browsing this forum: phil and 24 guests
